Antenna Bar
4 Answers 0 Score |
Battery not recognized after replacing swollen battery MacBook Air |
1 Answer 1 Score |
Overheating Problem that doesn't go away no matter what I do :( |
1 Answer 1 Score |
Can you change the MacBook Air 13" (2019) SSD? |
3 Answers 0 Score |
MacBook Air Issues: Slow Performance, PFM006 Error, Battery Not Chargi |
Parts
Tools
These are some common tools used to work on this device. You might not need every tool for every procedure.
Models
A1932 (EMC 3184 MacBookAir8,2) 1.6 GHz
Background and Identification
After its complete redesign in 2018, Apple’s MacBook Air got a minor refresh for 2019—same processor and graphics hardware, but with the addition of True Tone technology and a slight tweak to the battery capacity. This model is designated MVFH2LL/A.
Specifications
Display
- 13.3" IPS panel with True Tone; 2560 x 1600 pixels (16:10 aspect ratio, 227 ppi). Lower resolutions supported
Processor
- 1.6 GHz (i5-8210Y) dual‑core Intel Core i5, Turbo Boost 3.6 GHz, with 4 MB L3‑cache
Graphics
- Intel UHD Graphics 617
Storage
- PCIe-based SSD with 128, 256, 512 GB or 1.5 TB options
Memory
- 8 GB of 2133 MHz LPDDR3 SDRAM
- Optional 16 GB
Camera
- FaceTime HD (720p)
Connectivity
- 802.11ac Wi-Fi; a/b/g/n compatible
- Bluetooth 4.2
Dimensions
- Width: 11.97 in (30.41 cm)
- Depth: 8.36 in (21.24 cm)
- Height: 0.61 in (1.56 cm) tapered to 0.16 in (0.41 cm)
- Weight: 2.75 lb (1.25 kg)
Peripheral Connections
- 2× Thunderbolt 3 port (USB-C 3.1)
- 1× 3.5 mm headphone jack
